Advice on New Build
Post Date: 2012-05-31
capmeo23 View Drop Down
  Quote capmeo23 Quote  Post ReplyReply bullet Topic: Advice on New Build
    Posted: 31 May 2012 at 11:38am
Looking to purchase a gaming computer for my son. Have limited knowledge on gaming computers. Was hoping for some good recommendations on a build.
Thank you
Budget - $3500-$4300
Expectations - Strictly a gaming computer. Would like high end graphics and maxed settings
Usage - Playing primarily Diablo III some Starcraft and City of Heroes
Special needs - Would like a good cooling system
Chassis Airflow: Upgrade Chassis With Zalman Performance Fans (Up to 6 Fans) <b></b>
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 31 May 2012 at 11:48am
Hi capmeo23.....Welcome to the forums.
Couple of things...need to know what size monitor and resolution you play with.
The X79 platfrom in Dreadnought level 3 is really more than you need for gaming.  It's quad channel memory and the i7-3930k 6 core cpu are more for video editing, rendering, 3D modeling and other apps that suck up RAM usage.  Nothing wrong with it and if budget allows then go for it.
Start with the Dreadnought level 2 , go with sli, 2x 670 and see what you think.  If this is a rig for 23/24" monitor with 1920x1080 resolution then the sli 670 will max out the gaming for alot less( $500)  than sli 680 and almost the same performance.
With the hafX case, you picked the best for air cooling.
Those Zalman fans are very noisy and not needed with the HafX case, which is great as-is.
Hope this helps.
Here's the build I was talking about.  Thought I had to go but not for a few minutes.Big%20Smile
Config # 694460       Cost $ 2902
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 670 2GB (Includes PhysX)
I believe this would be about $900 cheaper for the same gaming on a 24" monitor.
Good LuckBig%20SmileBig%20Smile
Edited by bprat22 - 31 May 2012 at 12:10pm
  Quote capmeo23 Quote  Post ReplyReply bullet Posted: 31 May 2012 at 12:36pm
Thanks very much bprat22 - I will also need a monitor 24"-27" range.  This is adddition to budget above. I see a lot of people are recomeending the Dell Ultrasharp. Would appreciate a recommendation on this as well.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 31 May 2012 at 1:01pm
Others will weigh in, but I game on last years version of the Dell UltraSharp U2312hm and its great.    If you go 27" then the resolution jumps to 2560x1440.    This res. Requires more video power but the games you mentioned I believe would still max out.     Games like BF3 and Metro2033 on the 27" would drop the fps into the 50's at times maybe a bit lower on maxed out settings.     Still very good gaming.
  Quote capmeo23 Quote  Post ReplyReply bullet Posted: 01 Jun 2012 at 7:43am
I would appreciate some opinions on the below changes to the build:
I was considering utilizing a wireless card for internet acess, if so do you think I should utilize the ASUS P8Z77-V DELUXE MOBO?
Also, did some research on the Noctua cooling system, very nice system. Should I keep that or go with the Vortex 240mm liguid cooling?
Lastly, from a performance standpoint is upgrading the GTX 750 from 2GB to 4GB worth it? I will probably go with the Dell UltraSharp U2312h monitor.
Thanks again.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 01 Jun 2012 at 8:26am
Hi capmeo23,
If I was going wireless I would pick the Deluxe Mobo that includes Wireless and Bluetooth. That saves you from using a slot for the card. Then if the internal fails for some reason you can add a card later. They both offer the same version of wireless.
The D14 Noctua is a proven reliable design. The Vortex offers a few degrees better cooling with the 3930. The D14 is a huge big radiator with two fans that partially blocks some of the memory sticks. DS has stated a preference for the Vortex style of cooler for the 3930. The Vortex is a more complex system with a pump and reservoir of liquid. It is a closed system that doesn't require any maintenance. The Vortex is easy but expensive to replace. The only thing that can fail on the D14 is one of the two 120mm fans. So go with slightly better cooling but more potential problems with the Vortex. Or, go with slightly less cooling but simpler design of the D14.
Edited by FrankW - 01 Jun 2012 at 8:28am
kane860 View Drop Down
  Quote kane860 Quote  Post ReplyReply bullet Posted: 02 Jun 2012 at 7:29pm
I would def go with the Noctua D14 over the Vortex.. I would only recommend any kind of liquid cooling if you plan on going with stage 4 or higher..
System:
