Advice on my config
Post Date: 2011-08-02
Frenchman View Drop Down
  Quote Frenchman Quote  Post ReplyReply bullet Topic: Advice on my config
    Posted: 02 Aug 2011 at 1:10pm
Hey guys,
I spent the last couple of days playing around the site and reading your advices/suggestions. I want to buy a gaming machine and get the most bang for my buck. I posted all the information below.
Let me know what you think. Thank you!
$1500/$1700
Solid build for the next couple of years, great graphics and frame rate.
Exclusively gaming
[None
Saved Ticket #:
Ticket Number: 582299
Processor: Intel Core i5 2500K 3.30GHz (Unlocked CPU for Extreme Overclocking) (Quad Core)
Motherboard: ASUS P8P67 (Intel P67 Chipset) (New B3 Revision) (Does Not Support SLI)
Power Supply: 750W Digital Storm Certified (Dual SLI Compatible) (Silent Edition Recommended)
Hard Drive Set 1: Operating System: 1x (1TB Hitachi/Seagate (7200 RPM) (32MB Cache)
Video Card: 1x NVIDIA GeForce GTX 570 1.2GB (Includes PhysX Technology) <b></b>
Extreme Cooling: Standard Factory Heat-sink and Fan (Not Recommended for CPU Overclocking)
Boost Processor: FREE: Overclock the processor between 3.3GHz to 3.9GHz
Benchmarking: - No Thanks
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 02 Aug 2011 at 1:19pm
big no to that, check out ode 1, you get lot more then that.
This page was generated in 5.078125E-02 seconds.
