Adding components.Post Date: 2014-02-17 |
Infamous J
Newbie Joined: 12 Feb 2014 Online Status: Offline Posts: 6 |
Topic: Adding components. Posted: 17 Feb 2014 at 7:02pm |
So my Vanquish lv 3 system will be here in 4 days. I bought a Samsung ssd but I was curious if upgrading components and such does anything to the warranty? I haven't seen the inside but I assume the power connection is probably hidden pretty well and wasn't sure if it would be too much of a pain to re run any wires or whatever. Any advice would greatly appreciated.
fstcvc
Quote Reply Posted: 17 Feb 2014 at 8:36pm |
DS Warranty Info
Section C gives a clear answer to your question (simply, no it doesn't void your warranty). |
HailStorm II
Quote Reply Posted: 18 Feb 2014 at 2:39am |
Behind the right side cover should be extra power connectors from the psu for the drives. Running the Sata data cable from drive to the mobo will be a snap. The accessory box might have an extra if needed.
Edited by bprat22 - 18 Feb 2014 at 2:42am |
Infamous J
Quote Reply Posted: 18 Feb 2014 at 8:05am |
I must have missed that part. Thank you both for your help. I'm super excited!
Infamous J
Quote Reply Posted: 19 Feb 2014 at 8:10am |
Well my SSD came in today and has nothing but a disc and manuals. Any chance the mobo comes with an extra sata cable?
Quote Reply Posted: 19 Feb 2014 at 8:16am |
DS does send whatever parts are left over after the build. Not unusual to have an extra sata cable included, but can't say for certain.
Quote Reply Posted: 19 Feb 2014 at 2:29pm |
Check the accessories box, there might be an extra SATA cable, if not, you'll need to get one, but they are fairly cheap.
Infamous J
Quote Reply Posted: 19 Feb 2014 at 8:11pm |
Thank you all for your help. DS has built a great community of people wanting to help.
