Adding A Case Fan Need AdvicePost Date: 2012-08-02 |
rsmilford
Newbie Joined: 22 Jul 2010 Online Status: Offline Posts: 32 |
Topic: Adding A Case Fan Need Advice Posted: 02 Aug 2012 at 12:21pm |
Ok, so I have decided to add a case fan to my Old Silverstone TJ02 Window. This case has poor negative airflow and i plan on getting a little positive airflow with this upgrade.
I will be using a Cooler Master MegaFlow 200 Silent Fan (Intake) I have already ordered the fan. http://www.coolermaster.com/product.php?product_id=6492 And a 200mm x 230mm Silver Fan Grill (Outside of the window) I have not ordered the Grill yet. http://www.frozencpu.com/products/5318/ffg-22/200mm_x_230mm_Silver_Fan_Grill_-_Antec_Big_Boy_Cooler_Master.html?tl=g47c221s1053 My Question is what Hardware will i need to reach from the fan through the window and grill? Am I taking the right approach? Any suggestions or ideas are welcomed! |
rsmilford
Quote Reply Posted: 02 Aug 2012 at 12:31pm |
Almost forgot the Specs
Build: 6724 SilverStone TJ02 Power Supply: 550W Corsair HX Motherboard: nVidia 750i SLI FTW Processor: Intel Core 2 Quad Q6600 Heatsink: Freezer Pro 7 Video Card: 560Ti 448 cores Classified Edition(EVGA) Memory: Patriot PC2-8500 1066MHz 4GB Hard Drive: 160GB Western Digital |
Quote Reply Posted: 02 Aug 2012 at 2:04pm |
Hi rsmilford,
I am not a fan of the TJO2 case due to its limited cooling. I hope you added the rear 120mm fan already. It is a mistake that this rear fan is not included with the case. The limitation you might have is the distance from the side plate to cards. This is a mid-sized case and is there room to mount the fan? Let us know how it turns out. Frank |
rsmilford
Quote Reply Posted: 02 Aug 2012 at 2:29pm |
This is what im working with i think its a TJ02 Maybe TJ04 I dunno its older 2008 on the receipt digital storm called it the 750Si Case |
rsmilford
Quote Reply Posted: 02 Aug 2012 at 2:48pm |
I think i have enough room about 2 1/2 inches.
does anyone know what thread size the Cooler Master MegaFlow 200mmx200mmx30mm fan takes? Edited by rsmilford - 02 Aug 2012 at 2:48pm |
Admin Group Digital Storm Supervisor Joined: 04 Jun 2012 Online Status: Online Posts: 16314 |
Quote Reply Posted: 02 Aug 2012 at 5:27pm |
The best solution for that chassis is to drill 120mm holes for fan mounts.
Place them on the window.
xii
Quote Reply Posted: 04 Aug 2012 at 2:11am |
NIce deer. The PC ran it over. I approve.
rsmilford
Quote Reply Posted: 08 Aug 2012 at 6:57pm |
Success I recommend using a Rotozip with a spiral cutting device for perfectly measured holes. Edited by rsmilford - 08 Aug 2012 at 6:59pm |
Quote Reply Posted: 09 Aug 2012 at 5:19am |
Nice job.
Edited by bprat22 - 09 Aug 2012 at 5:19am |
Asangard
DS Veteran Joined: 21 Aug 2009 Online Status: Offline Posts: 2209 |
Quote Reply Posted: 09 Aug 2012 at 9:27am |
congrats looks great
Not from Without, Therefore, the 1st step on the Holy Warrior path, Is to recognize thyself as thy 1st enemy. |
shot
Groupie Joined: 22 Jun 2012 Online Status: Offline Posts: 244 |
Quote Reply Posted: 09 Aug 2012 at 12:35pm |
From what I can see that really did turn out well. OCD much? |
Intel i7-8700k
ASUS ORG STRIX Z370-H 16GB DDR4 3000mhz DSPS 1000W Corsair HX1000i SSD M.2 1TB 960 PRO SSD 256GB 850 PRO GTX 1080Ti 11GB Sound Blaster Z |
Quote Reply Posted: 09 Aug 2012 at 12:53pm |
rsmilford, that looks terrific. I can't even see the hole you cut into the plastic for the fan to draw air.
Frank |
xii
Quote Reply Posted: 09 Aug 2012 at 2:02pm |
Wow... Fantastic work! Wow.
