980 SLI OwnersPost Date: 2015-03-24 |
Clay
Topic: 980 SLI Owners Posted: 24 Mar 2015 at 3:49pm |
Ok, last week, I posted something in regards to my i7 5960 and FPS. That was a bad post I will have to admit.
Ok, having such power with the dual 980's, do you think using one for Physx would be a waste? Your thoughts... thanks! |
I7 13700KF 5.4hz
Quote Reply Posted: 24 Mar 2015 at 5:42pm |
Yes, it automatically load balances between the GPUs. The only time when you want to select a GPU for Physx is when you have a heterogeneous set-up where SLI is not available (Once DirectX 12 games start to appear, you then won't even want to do it then, either).
Clay
Quote Reply Posted: 24 Mar 2015 at 7:04pm |
I think I almost understood that. Sooo, for right now, its good to have one card for Physx?
I7 13700KF 5.4hz
Quote Reply Posted: 24 Mar 2015 at 7:46pm |
No, you'd be better off not dedicating a card to PhysX. (The "Yes" had been in response to the question of if it would be a waste)
Clay
Quote Reply Posted: 24 Mar 2015 at 7:48pm |
Sounds good! Thanks for the insight!!
I7 13700KF 5.4hz
