780i motherboard
Post Date: 2008-11-11
13cizma View Drop Down
  Quote 13cizma Quote  Post ReplyReply bullet Topic: 780i motherboard
    Posted: 11 Nov 2008 at 10:31pm
Can you redirect the heat away from the GPU that the 780i motherboard creates?
Its like half or more than half of the heat goes to the GPU and then the other half/quarter heat moves up to the back/top of the Case. It''s like its the culprit on why the GPU's temperature suddenly goes up while playing and doing extensive stuffs on the DS System.
Any ideas? or maybe it's just me fuzzing about this issue.Star
Just read around here at the forums that 790i motherboard has the same thing. Correct me if I am wrong.Ouch
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Nov 2008 at 11:00pm
your GPUs normally are warmer then the rest of your stuff when you put them underload they stat to get even warmer
Edited by DST4ME - 11 Nov 2008 at 11:01pm
XpubuX View Drop Down
  Quote XpubuX Quote  Post ReplyReply bullet Posted: 11 Nov 2008 at 11:05pm
Now the 780i chipset gets real freakin hot thats for sure. Sure am thinking about going liquid cooling on cpu and chipset but the chipset may be to big of a pain well see.
  Quote 13cizma Quote  Post ReplyReply bullet Posted: 11 Nov 2008 at 11:09pm
when you feel the Heatsink (I don't know if the real name is the heatsink) using your hands you can feel that the Heatsink is blowing/exhausting heat to the GPU. So, it adds up right? Produced b y the GPU heat + the Heat exhaust from the Heatsink thing.
Is there any way maybe to modify this or get a special Modification or something.
This page was generated in 0.25 seconds.
