5k-6k configurationPost Date: 2015-03-03 |
Tunapiano
Newbie Joined: 03 Mar 2015 Online Status: Offline Posts: 5 |
Topic: 5k-6k configuration Posted: 03 Mar 2015 at 1:50pm |
5k-6k already have 3 storage drives and peripherals/monitor from my PC i am replacing. Expectations: High end gaming PC for the next 5+ years. Usage: everyday gaming. Question:I have one question and that's about the PSU, whether or not 1200 is overkill for this system. now you have to take into account that i have 1tb and 3tb 7200rpm storage drives i'll be adding and a 500gb 10000 rpm gaming drive. Specifications: System Configuration: Chassis Model: Special Deal Hot Seller - Black OPS Aventum II Exterior Finish: Onyx Black Matte Finish with Red Stand Trim Accents: - Not Available Processor: Intel Core i7 Extreme Edition 5960X 3.0GHz (Eight-Core) (Extreme Performance) Motherboard: ASUS X99 RAMPAGE V (Intel X99 Chipset) System Memory: 32GB DDR4 2666MHz Corsair Vengeance LPX (High-Performance) Power Supply: 1200W Corsair AX1200i (Digitally Controlled Power) Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 8x / CD-Writer 8x) Storage Set 1: 1x SSD (120GB Samsung 850 EVO) Storage Set 2: - No Thanks Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x NVIDIA GeForce GTX 980 4GB (ASUS Strix Edition) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: HydroLux Level 1: Digital Storm Exotic Custom Cooling System (CPU Only) H20 Tube Color: Red Tubing with High-Performance Fluid (UV Lighting Reactive) Chassis Fans: Upgrade All Fans to Corsair Airflow Performance Edition (Up to 6 Fans) Internal Lighting: Digital Storm RGB LED Lighting System (Requires Thermal Management Control Board & Software) Airflow Control: Digital Storm Thermal Management Control Board & Software Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks CPU Boost: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Graphics Boost: - No Thanks, Please do not overclock my video card(s) Memory Boost: - No Thanks, Please do not overclock my memory OS Boost: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks NVIDIA SHIELD: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 15-20 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 4 Year Limited Warranty (4 Year Labor & 2 Year Part Replacement) |
Quote Reply Posted: 03 Mar 2015 at 2:20pm |
Hi Tunapiano,
What is your configuration number? This is way over kill for a gaming machine with a single 980 GPU. You don't need the 5960X CPU, 32Gb memory, Hydrolux cooling, the 1200w PS or even the Aventum II case. You do need a bigger SSD and the Pro model is a better choice. Now that doesn't mean that you can't have all of that if you want it. But, it won't game any better than a system with a lot lower level of equipment. You seem to have a lot of storage capacity and I wonder if you are doing other work than gaming? If you like your build then go for it. You will be able to run amuck with your games on a 1920 x 1080 monitor. |
Tunapiano
Quote Reply Posted: 03 Mar 2015 at 2:29pm |
i run on a 2560x1440p 27 inch monitor and i tend to do a lot of multitasking though streaming, gaming and ripping my movies are primarily what i do.
As for the SSD i won't be putting anything on it but the OS so i don't see why i'd need better than 120gb. As for the GPU, in my system i'm replacing i had it built with SLI 580's back in the day and it seemed like overkill then, these days very few games seem to push a 980 let alone 2 980's which are overkill. The memory needs to be a minimum 16gb because i do multitask and constantly using over 10gb of ram at any given time and that will definitely be going up over time as it always has with games needing more vram and ram. The CPU is to make sure i have a high end CPU years from now, i like to build a PC that lasts a minimum of 5 years with only the GPU ever needing upgraded. WHy not use the Hydrolux cooling? and if not the 1200w PSU then what would you suggest? |
michaeljhuman
Quote Reply Posted: 03 Mar 2015 at 2:47pm |
Two 980s are not overkill for 4k gaming, IMO. So consider what your future display rez will be
For a gaming PC, I would say the 5820K is quite reasonable, looking into the future. More games make utilize more cores into the future. If you feel that's not true, get the fastest 4 core, 4790, but realize that won't be an X99 chipset. If you like X99, get the 2820 The Rampage doesn't make a lot of sense when I looked at it. I could not see a reason to choose it over something like the Asus X99 Deluxe, unless you are sufficiently in love with the ROG look and don't mind the upcharge. Nothing wrong with that power supply, but overkill unless you are going SLI ( and even then, a bit of overkill, but it IS a bit sexier as PSUs go :) This is just one man's opinion :) |
Tunapiano
Quote Reply Posted: 03 Mar 2015 at 3:57pm |
Well you guys got me thinking and this is the configuration i went with when placing my order.
System Configuration: Chassis Model: Special Deal Hot Seller - Hailstorm II Edition Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 5820K 3.3GHz (Six-Core) (Unlocked CPU) Motherboard: ASUS X99-DELUXE (Intel X99 Chipset) System Memory: 32GB DDR4 2666MHz Corsair Vengeance LPX (High-Performance) Power Supply: 1200W Corsair AX1200i (Digitally Controlled Power) Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x SSD (128GB Samsung 850 PRO) Storage Set 2: - No Thanks Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 980 4GB (ASUS Strix Edition) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: HydroLux Level 3: Digital Storm Exotic Custom Cooling System (2x Video Cards + CPU + Chipset) H20 Tube Color: Red Tubing with High-Performance Fluid (UV Lighting Reactive) Chassis Fans: Upgrade All Fans to Corsair Airflow Performance Edition (Up to 6 Fans) Internal Lighting: Remote Controlled LED Lighting System (Multiple color options and lighting effects) Airflow Control: Digital Storm Thermal Management Control Board & Software Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks CPU Boost: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Graphics Boost: - No Thanks, Please do not overclock my video card(s) Memory Boost: - No Thanks, Please do not overclock my memory OS Boost: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks NVIDIA SHIELD: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 4 Year Limited Warranty (4 Year Labor & 2 Year Part Replacement) |
michaeljhuman
Quote Reply Posted: 03 Mar 2015 at 4:11pm |
128 GB is not a lot for the system drive.
I have a lot of games, and I use quite a lot of my 256 GB system drive and a 1 TB data drive |
Tunapiano
Quote Reply Posted: 03 Mar 2015 at 4:43pm |
It is when you're not installing any games on the system drive, that's what the 500gb 10,000 rpm drive is for. I don't trust SSD's for gaming, i have had 2 fail on me that i would keep 1 or 2 games installed on because i do game everyday.
Quote Reply Posted: 03 Mar 2015 at 4:57pm |
This is a lot better balanced than your first system. I think you are going to like it a lot.
Frank |
Kaelara
Quote Reply Posted: 03 Mar 2015 at 5:19pm |
I agree.. kind of what I would have considered IF I went for a water cooled system.. I opted for Air Cooled and chose a different Case because of that choice.. To be honest the more parts you have in any computer even a well built one the more that can and often will go wrong. I play two of the biggest resource hogs in terms of Disk space WoW, with tons of Addon's and Sims 3 all expacs and tons of custom stuff , in addition to just adding Sims 4 these games use up a lot of space.. The one thing that I do not do that is a space hog is store videos, and photos. As for Photos I am still a very much Old School photographer I can not even afford the digital camera that I would need to replace and do what my film camera does for the price of that digital cameral I could have bought three of the Velox Systems I just got and still would only have the camera body and one lense... SO no need to consider a hard drive for my photography need unless that camera comes down in price a lot... Enjoy your system I think you will like it |
Kaelara
Tunapiano
Quote Reply Posted: 03 Mar 2015 at 7:19pm |
Well my current system is liquid cooled and i never had a problem with it 5 years later. It definitely cuts down on the noise.
And i have over 300 movies that i've been ripping onto the storage disks and a huge music collection. |
Clay
Quote Reply Posted: 05 Apr 2015 at 4:53pm |
Hows the system treating you?
I7 13700KF 5.4hz
