4KILLER MACHINEPost Date: 2015-04-19 |
nofuture
Newbie Joined: 18 Apr 2015 Online Status: Offline Posts: 4 |
Topic: 4KILLER MACHINE Posted: 19 Apr 2015 at 1:03am |
You can see my approximate configuration as config 1181973. I wish to see if Digital storm will make some custom changes to the system. The changes are as follows. 1. Instead of a tower case I would like a 4U RackMount Case. My preference is the ARK 4U-500-CA Black 4U Rackmount Case 3 External 5.25" Drive Bays2.I would like the motherboard to be the ASRock X99 WS-E/10G LGA 2011 Intel X99 SATA 6Gb/s USB 3.0 Extended ATX Intel Motherboard3.I would like to have as my boot disk a SAMSUNG XP941 Series MZHPU512HCGL-00004(0) M.2 512GB PCIe Gen2 5Gb/s up to 4 lanes MLC Internal Solid State Drive (SSD) - OEMconnected to the M.2 port on the motherboard and ensure that operates at full speed (PCI-E x 4). If the SATA ports are not configured right the speeds will drop. Please see the motherboard manual. So in all I wish to have:pecifications: SAMSUNG XP941 Series MZHPU512HCGL-00004(0) M.2 512GB PCIe Gen2 5Gb/s up to 4 lanes MLC Internal Solid State Drive (SSD) - OEM
Graphics Card(s): 4x SLI Quad (NVIDIA GeForce GTX TITAN X 12GB (Includes PhysX) <br><strong></strong> |
Quote Reply Posted: 19 Apr 2015 at 1:07am |
Your best bet is to contact DS directly at [email protected] or call them Monday morning (9am PDT) and talk to the sales folks there.
Sometimes they will bounce around the forums on weekends and perhaps you'll get an answer. Cheers. |
nofuture
Quote Reply Posted: 19 Apr 2015 at 1:11am |
Thanks for the tip :)
Quote Reply Posted: 19 Apr 2015 at 1:30am |
You can do 3 GPUs, not 4...there are only 7 PCI slots in the chassis and each of the GPUs requires 4. You'd have to go with something like http://www.newegg.com/Product/Product.aspx?Item=9SIA25V2MP9924 in order to fit 4 cards. Getting watercooling into these chassis' will not be simple, it even possible; you may want/need to go with an air cooler for the CPU.
With the motherboard, you should check into seeing if there is any support for NVMe. Even though the interface is PCI-e 2.0, you will benefit from the SM-951 with NVMe's reduced transport overhead, if doable. Also, you should be aware that the graphics cards will have less bandwidth to the GPUs on that board (32 lanes) than something like the ASUS Rampage V Extreme (40 lanes). You'll want to talk to John at DS; he handles the custom build configuration stuff. |
Quote Reply Posted: 19 Apr 2015 at 6:08am |
Hi nofuture,
That is a wild system and you must have some special application. I think we would be interested in your planned use of the system? I think your timing is off target for the new NVMe SSDs. I think you will need a PCIe-X4-3.0 for the SM-951 or the Intel 750 NVMe cards. There is also a Bios problem for these drives. Since DS has the Intel 750 listed maybe they have a Bios solution already. This is all new and possible fraught with problems. You may not be able to get the exact motherboard you want that will have an upgraded NVMe Bios. DS will take care of your special request for a fee. You can email John at [email protected]. Good luck with your system. Frank Edited by FrankW - 19 Apr 2015 at 6:11am |
nofuture
Quote Reply Posted: 20 Apr 2015 at 5:16pm |
Thanks for the chassis advice. with the PLX controllers on the as rock motherboardwe should be good with lane count. The video cards have so much RAM that the PCIe bus shouldn't be a bottleneck. I have. a Intel p3700 SSD on hand but I would rather not use it if I can use the Samsung m.2 interface. That way it can still be quad sli and also have the high SSD x 4 speed. Edited by nofuture - 20 Apr 2015 at 5:18pm |
nofuture
Quote Reply Posted: 20 Apr 2015 at 5:42pm |
I have an Intel P3700 SSD on hand. I haven't had problems with it. Only reason I am not using it or this build is so I can still make the system quad SI. That's why I was looking at M.2 devices. I had a lot of trouble getting those to work with the asus x99 deluxe. You are right about all of this being so new that it is fraught with problems. This is ffor a high net worth individual who Is creating a video distribution system in his home. over 30 4K large displays throughout the home with content streaming to all of them at simultaneously. Right now most content is served from a 72 tb NAS which has a 10 gigabit network interface. He will have fiber soon. Not sure if he will get the 1'gigabit service or the 10 gigabit. When he gets he the fiber he will want streaming from live sources as well. This machine is for content creation and game playing all in 4k@60hz. The game playing itself is a form of content creation in terms of streaming his sessions. |
Quote Reply Posted: 20 Apr 2015 at 6:01pm |
You're going to get maybe two 2160p60 streams off of a machine like this. If you want to do video content, I'd suggest waiting...the hardware decode isn't up to snuff on the 970's, 980's, or Titan X's, only on the lower GTX 960's: http://www.anandtech.com/show/9152/futureproofing-htpcs-for-the-4k-era-hdmi-hdcp-and-hevc. The R9 300's should be the first GPU's capable of 2160p60 gaming and hopefully have full hardware decode.
To be honest, you'd probably be better off with a distributed system with remote maintenance rather than a centralized system. |
