4K UHD Question
Post Date: 2015-04-25
ggo4th View Drop Down
  Quote ggo4th Quote  Post ReplyReply bullet Topic: 4K UHD Question
    Posted: 25 Apr 2015 at 1:09am
Hey gang. I've recently purchased the below rig from Digital Storm and had a question regarding getting a 4K monitor for it. It's currently being built, so I have a little time before it gets here and I'm looking at possibly picking up an ASUS PB287Q 28-Inch Screen LED-Lit 4K Monitor. I was wondering if this rig would do a decent job running 4K... or, if I'm better off looking at 1080p? This will be my first experience with 4K (if I end up going that route). So any thoughts, criticisms or other direction is appreciated! I'll be using it mainly for my home PC (movies, gaming, general usage, etc.) but may also do some video editing/graphic design work on it. Thanks guys. Here's the new system:
System Configuration:
Chassis Model: Digital Storm Apollo
Motherboard: ASUS MAXIMUS VII HERO (Intel Z97 Chipset) (The Ultimate Power Platform)
System Memory: 16GB DDR3 1866MHz Corsair Dominator Platinum DHX (Extreme-Performance)
Power Supply: 1050W Corsair HX1050
Storage Set 1: 1x SSD (256GB Samsung 850 PRO)
Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 970 4GB (EVGA ACX Cooler Edition)
Sound Card: Creative Sound Blaster Zx (Includes Audio Control Module)
Extreme Cooling: !CLEARANCE: H20: Stage 2: Corsair H110 280mm Radiator Liquid CPU Cooler (Extreme Performance)
Chassis Fans: Upgrade Chassis With LED Performance Fans (Blue) (Up to 6 Fans)
CPU Boost: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires High-End Motherboard Selection)
Graphics Boost: Yes, Overclock the video card(s) as much as possible with complete stability
Windows OS: Microsoft Windows 8.1 Professional (64-Bit Edition)
Keyboard: Corsair Vengeance K95 (Fully Mechanical Gaming Keyboard) (Black Brushed Aluminum Finish)
Mouse: Corsair Vengeance M95 (Laser 8200 dpi) (MMO and RTS Gaming Mouse) (USB Wired)
Speakers: Klipsch ProMedia 2.1 Computer Speakers
Headset: Klipsch KG-300 Pro Audio Gaming Headset
Edited by ggo4th - 25 Apr 2015 at 1:31am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 25 Apr 2015 at 3:45am
Hi ggo4th........ Welcome to the forums.
Nice setup and you will get decent gaming on 4k, but not on the highest settings.   Some games will and some won't.
Here's a link to see some results......
http://www.guru3d.com/articles_pages/geforce_gtx_970_sli_review,21.html
  Quote ggo4th Quote  Post ReplyReply bullet Posted: 25 Apr 2015 at 8:06am
Thanks, bprat22. That does help! Another question that I had that maybe you or someone on here could help me answer... it looks like a good idea to go ahead and get the 4K monitor, but what will 1080p look like on a 4K monitor? Will it be worse or better than a traditional HD monitor? Thanks again.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 25 Apr 2015 at 8:07am
Hi ggo4th,
I think you will be a little short with dual 970s and 4K.  Why not consider a
2560 x 1440 monitor.  There are available in several 27" monitors.  This is a good compromise resolution.
  Quote ggo4th Quote  Post ReplyReply bullet Posted: 25 Apr 2015 at 8:13am
Hey Frank. I'm up for considering going either way with the monitor. I just want to get whichever will be best performance wise and ideally not waste either money getting a 4K monitor or performance getting a lesser resolution. If this rig can do 4K at a decent level, (which given the results bprat22 dug up at http://www.guru3d.com/articles_pages/geforce_gtx_970_sli_review,21.html it looks like it may be decent) I think I'd prefer to get the 4K monitor. But, if it's not worth it to do performance wise, I think I'd rather save the $$$ and get something that would be. It looks like this rig may be right on the line, so it's a tough call! What are some good 2560x1440 monitors that you'd recommend? Thanks!
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 25 Apr 2015 at 9:06am
The higher the res, the lower the performance for sure.  In the link I posted, Metro Last Light for example, in 1080p you'd get 100fps, in 2560x1440 you'd get 70fps and in 4K you'd drop to 40fps with the settings all the same.
sli 970 will play in 4K but, like Frank said, the 2560x1440 would be a good compromise of quality and value.   4K is the equivalent of 4x 1080p monitors.
I've never worked with 4K, not in my budgetBig%20Smile, but I'd stick with 1080p or the 1440p with a sli 970 setup.
  Quote ggo4th Quote  Post ReplyReply bullet Posted: 25 Apr 2015 at 9:14am
Point well taken fellas. I appreciate all of the insight. Haha like you, I've never worked with 4K, either. It's somewhere around a $100 (or so) difference to go from 1440 to 4K, so I guess the question at this point would be is it worth it to get the 4K for future use (say I get a Titan X down the road or something) and just run the things that don't run well on 4K with the 970's in 1080p on the 4K monitor? I've seen some back in forth on other forums about how 1080p looks in 4K, but never from anyone that's actually experienced it. That would really be helpful if someone has actual experience with it. I really appreciate the advice guys. I'm starting to think I should've kicked in the extra $$$ for the Titan X in the first place. lol
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 25 Apr 2015 at 9:23am
The sli 970 actually performs better than a single Titan X in most cases.   You'd need to go sli Titan X to get better in 4K.
  Quote ggo4th Quote  Post ReplyReply bullet Posted: 25 Apr 2015 at 9:24am
Whew! I'd need to get a second job first! lol
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 25 Apr 2015 at 10:14am
LOL  Yeah, I hear that.
Don't want to talk you outta 4K.   The sli 970 will play in 4K as the charts show, just that as time goes on the demands will only get greater with gaming demanding more and more.   You could get the 4K , play and probably be more than happy with the 970s, and in the future, a year or two,  upgrade to stronger, newer  generation cards.
Tough call. Big%20Smile
  Quote ggo4th Quote  Post ReplyReply bullet Posted: 25 Apr 2015 at 12:52pm
I know, right? My only concern would be that 1080p wouldn't look good on the 4k monitor. I understand that it would necessarily distort the image a bit to go from 4k to 1440, but that's ok. I don't mind 1080. If I knew that it'd still look good in 1080, I'd just as soon get the 4K monitor and use it here and there. Thanks again!
Edited by ggo4th - 25 Apr 2015 at 1:24pm
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 26 Apr 2015 at 4:43pm
I played Assassin's Creed Unity scaled down to 1080p60 on my 2160p60 TV with a single 970 and it looked fine to me. I've also been able to play less demanding games at 2160p60 with no problems, as well.
  Quote ggo4th Quote  Post ReplyReply bullet Posted: 26 Apr 2015 at 7:37pm
That's what I was looking for! Thank you sir! I guess I'll just go ahead and get the 4K monitor. I appreciate all of the help fellas.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 27 Apr 2015 at 5:40am
Hi ggo4th
A 4K TV is not the same as a 4K monitor.  A monitor may or may not scale a 1080 signal to 4K with good results.  It depends on the design of the monitor.  TVs are designed to received a 1080 or 720 signal.  A monitor may or may not be designed to handle/scale a 1080 signal with good results.  Google 1080 on a 4k monitor and you will see a bunch of discussion about how it works, or if it will work.  I would not buy a 4K monitor to play 1080 unless I have seen it work from a computer at 1080.  Of course it is your money and your choice.  Just do your homework before you make a decision.
  Quote ggo4th Quote  Post ReplyReply bullet Posted: 27 Apr 2015 at 11:24am
Hey Frank. Thanks for the response. I'm still strongly considering the ASUS 28" monitor, so I'll go ahead and check around to see how well it handles 1080p. Thanks again.
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 27 Apr 2015 at 11:30am
My scaling is done strictly through the graphics card. The interface to the TV is a static 2160p60.
  Quote ggo4th Quote  Post ReplyReply bullet Posted: 29 Apr 2015 at 11:16pm
So, after much deliberation, here's what I just ordered:
Thanks again for the insight fellas.
