3DMark 11 problem (might be my system)
Post Date: 2012-05-21
sbq View Drop Down
  Quote sbq Quote  Post ReplyReply bullet Topic: 3DMark 11 problem (might be my system)
    Posted: 21 May 2012 at 9:21pm
I've been having some BSOD and black screen reboot issues when playing certain games (Diablo 3, Tera) so I cleaned up some stuff from my system and installed the 3DMark 11 Basic to test my system, but when I run it I usually get a messed up screen like this:
Link because insert image doesn't like Dropbox
Though some of the tests will run normally. I've got a GTX 580 and I'm running on a 27" Dell monitor at 2560 x 1440 resolution. I've posted on the Futuremark forums after searching for something similar but I have to wait for an admin to approve my post, and I'm terrible at waiting, so I figured I'd post here too.
Here's my current setup:
System Configuration:
Chassis Model: Digital Storm 950Si
Processor: Intel Core i7 Extreme Edition 965 3.2GHz (Quad Core) (OC'd to 3.85 GHz)
Motherboard: ASUS P6T Deluxe (Intel X58 Chipset) (Supports Dual SLI or CrossFire)
System Memory: 6GB DDR3 1600MHz OCZ (High-Performance)
Power Supply: 1000W Corsair HX (Dual/Triple/Quad SLI Compatible)
Hard Drive Set 1: Operating System: 300GB Western Digital VelociRaptor (10K RPM) (16MB Cache) (Extreme Speed)
Hard Drive Set 2: Multimedia\Data: 300GB Western Digital VelociRaptor (10K RPM) (16MB Cache) (Extreme Speed)
Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x) (LightScribe Edition)
Video Card(s): 1x nVidia GTX 580 1.5GB (not original to this config, was upgrade form 4870 X2 I got with this system)
Extreme Cooling: H20: Stage 3: High-Performance Liquid Chilled FrostBite System For CPU
Chassis Airflow: Upgrade Chassis With Zalman Performance Fans
Enhancements: LCD Temperature Display & Fan Controller (Requires Chassis Airflow Upgrade)
CPU Boost: Yes, Overclock the processor as much as possible with complete stability
Memory Boost: Yes, Overclock memory frequency (Includes Memory Fan Kit Installed)
Windows Boost: - No Thanks, Please do not tweak the services on the operating system
Windows OS: Now running Windows 7 Ultimate
Edited by sbq - 21 May 2012 at 9:27pm
sbq View Drop Down
  Quote sbq Quote  Post ReplyReply bullet Posted: 22 May 2012 at 11:36am
Ran it again using a display scaling mode of stretched instead of centered and it's running fine.
This page was generated in 3.320313E-02 seconds.
