360 ModPost Date: 2010-04-20 |
Fearnot
Newbie Joined: 07 Apr 2010 Online Status: Offline Posts: 76 |
Topic: 360 Mod Posted: 20 Apr 2010 at 3:55pm |
hmm anyone think its possible to do more than just a Liquid Cooling / LED modding to a Xbox 360?
Reason I ask is because I'm looking for a summer project to do, and since Cataclysm Beta probably won't be open for a while I will have nothing to do , everything will be on farm. So, thought Moddifying my Xbox 360 would be neat. Already have some LED's in it, and looking into the Liquid Cooling for it at the moment. If anyone has any ideas please feel free to share :) |
Bullseye
Senior Member Joined: 11 Jan 2010 Online Status: Offline Posts: 880 |
Quote Reply Posted: 21 Apr 2010 at 2:17am |
I have an idea:
How about you repaint it with gloss paint and make some designs? |
ablahblah
DS Veteran Joined: 12 Jun 2009 Online Status: Offline Posts: 2312 |
Quote Reply Posted: 21 Apr 2010 at 4:02pm |
LCs, finds boot drive, messes with it, overclocks 360, pwns all in MW2, muhuhahahaha....LOL
aight, now to be serious... I'd say one of the coolest mods you can do is to take a table, and fully integrate the internals of a 360 into it. As in, rip the internals out of the 360 itself, build a PC-like modification area in the table, and mount the internals in it. Table-integrated Xbox ^^ Or better yet, gut a large laptop case, and stick the 360 internals in THAT. Or just make a portable box for it yourself. Also find a way to stick in some sort of high-capacity 12v battery. Dunno whether the thing uses 12v or not, if it uses 115AC, just get one of those car inverters. After that, you'll have yourself a portable XBOX and will be revered as a geek on your block, but an AWESOME geek at that Edited by ablahblah - 21 Apr 2010 at 4:11pm |
R4D4RPR00F
Core i7 920 @ 3.9Ghz Asus Sabertooth X58 EVGA GTX 570 Mushkin 6GB 1414Mhz |
Bullseye
Quote Reply Posted: 22 Apr 2010 at 12:38am |
Lol. But that's actually pretty cool. You could get a 17 inch and with full HD but crappy specs. Then when you connect the 2 you will be playing at full HD on a 17 inch laptop screen!
Fearnot
Quote Reply Posted: 22 Apr 2010 at 1:57pm |
LOL thats not a bad idea :P
Wish i could put in a different vid card to replace the Processor lol didn't get a chance to look at forums till now :( been up for 48hrs straight, raiding for 40 of those 48 lol. |
Bullseye
Quote Reply Posted: 22 Apr 2010 at 3:52pm |
Lol wish I were you. Do your parents really let you play that long???
Bullseye
Quote Reply Posted: 22 Apr 2010 at 3:55pm |
Oh lol wait I just saw pro gamer. Yup I guess that was a pointless question...
ablahblah
Quote Reply Posted: 22 Apr 2010 at 8:46pm |
Figure out what makes a 360 run like a 360, image/install into a monster DS PC, boot, pwn all ur friends.
R4D4RPR00F
Bullseye
Quote Reply Posted: 23 Apr 2010 at 2:29am |
That's a good idea! Instead of connecting it to a laptop you could connect it to a ds system!
Fearnot
Quote Reply Posted: 05 May 2010 at 3:41pm |
lol, just finishing up the LC tmr on it, then gunna try to make a weird thing with it lol, basicly going to be a dual monitor set up with 2 xbox motherboards, 1 motherboard for each monitor rofl, all of them going to be joined to 1 body, should be neat
will it work, hell if i know |
ablahblah
Quote Reply Posted: 05 May 2010 at 4:29pm |
what, so you made a double xbox? kewl, you can be playing two different games at once with half the size
R4D4RPR00F
Fearnot
Quote Reply Posted: 06 May 2010 at 3:40pm |
basicly im going to take a case (not sure what of or what from ) or just make one , and make it so I can put 2 xbox motherboards in there, that will both operate at the same time, on different screens at the same time :P if It works will make Jtagging a hell of a lot easier, and would actually be pretty nice if I can import both of the screens into the case that wil be housing the motherboards!
Edit: Finished my LC on the one Xbox too, looks really nice, Have it all internally, very very very quiet, just a little note I had RRoD before I started with the LC and it wouldn't run more than 5min, been running it for 20hrs so far and no problem :P wish they would make LC standard on some Xbox models XD And bought another one yesturday off a friend of mine, will be turning that one into a Jtag tonight! Edited by Fearnot - 06 May 2010 at 3:44pm |
Fearnot
Quote Reply Posted: 06 May 2010 at 3:48pm |
Will be painting the 1 case I choose to use, not sure o nthe design will probably some brutal design to display a band I listen too rofl My friend is an amazing graphic designer , said he would look at what he or some of his friends could do ! should be sick! |
Bullseye
Quote Reply Posted: 06 May 2010 at 4:14pm |
Awesome good luck man!
Fearnot
Quote Reply Posted: 06 May 2010 at 9:18pm |
Fearnot
Quote Reply Posted: 18 May 2010 at 11:59am |
http://www.directron.com/lt80uvgn.html
Anyone know if these fans would be good to run in a 360? |
Bullseye
Quote Reply Posted: 30 May 2010 at 2:58am |
So how is it goin so far???
Fearnot
Quote Reply Posted: 01 Jun 2010 at 11:43am |
pretty good sofar, friend is still doing the design process for me, so soon as hes done i'll get to work on the LC :)
Bullseye
Quote Reply Posted: 01 Jun 2010 at 12:54pm |
Awesome, can't wait to see the finished version!
