some of the parts are not good choices so you will see them changed in my config, once you see something changed, even if its a lower model, understand it was changed because it offered the same performance as the higher model so there was no reason to go with the higher, none what so ever.
case fans will have nothing to do with your oc, your oc't temps mainly depend on the chip itself and the cpu cooler you put on it, the upgraded fans are loud, don't bother with them.
the 5970's vram max is actually 1GB, its 1GB per card in there.
Nvidia system:
Here you go Ticket# 412572 --- Price: $2673 (To see this build click here) Price after current promotion $2673
Copy of Specifications:
Chassis Model: Special Deal Hot Seller - Cooler Master HAF 932
Exterior Finish: - Not Available
Trim Accents: - Not Available
Motherboard: EVGA X58 LE Edition SLI (Intel X58 Chipset) (Supports SLI or CrossFire)
Power Supply: 1250W Enermax Galaxy EVO (Dual/Triple/Quad SLI Compatible) (Recommended)
Expansion Bay: - Not Available
Hard Drive Set 1: Operating System: 1x (500GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x)
Video Card: 2x SLI Dual (NVIDIA EVGA GeForce GTX 480 1.5GB (Includes PhysX Technology)
Extreme Cooling: AIR: Stage 2: Noctua NH-D14 Extreme Performance (Does NOT fit on the regular EVGA X58 3X SLI)
Enhancements: - Not Available
Chassis Mods: - Not Available
Noise Reduction: - Not Available
Boost Video Card: - Not Available
Boost Memory: - Not Available
Virus Protection: - Not Available
Office: - Not Available
Benchmarking: - Not Available
Install/Test Game: - Not Available
Warranty: 3 Year Limited Warranty with Life-Time Customer Support
Ati system:
Here you go Ticket# 412574 --- Price: $2463 (To see this build click here) Price after current promotion $2463
Power Supply: 1000W Corsair (Dual/Triple/Quad SLI Compatible)
Video Card: 2x CrossFire Dual (ATI Radeon HD 5870 1GB)
