1Yr old computer - Lag problem
Post Date: 2011-09-08
Utopi View Drop Down
  Quote Utopi Quote  Post ReplyReply bullet Topic: 1Yr old computer - Lag problem
    Posted: 08 Sep 2011 at 11:10am
The problem occurs when I either play a game or browse the internet and watch a movie on my other screen. Let's start with the specs.
HAF 932
CPU: Intel Core i7 930 @3.9GHz
MB: EVGA X58 LE Edition SLI (Intel X58 Chipset)
Memory: 6GB DDR3 1600MHz Digital Storm Certified Performance Series
PS: 1200W Digital Storm Certified (Dual/Triple/Quad SLI Compatible)
Main HD: 1x (40GB Solid State (By: Intel) (Model: X-25V Edition)
2nd HD: 1TB
GPU: 1x NVIDIA GeForce GTX 480 1.5GB (Includes PhysX Technology)
Air Stage 1 Cooling Noctua dual fan 120mm
1 24" Asus monitor 1920x1200
1 23" Acer monitor 1920x1080
SO, there's my PC. I have 7-8Gig left on my SSD, everything else is on the second HD.
Now, when I'm on the internet and a movie playing on the smaller screen, whenever i load a page my movie starts lagging and the sound skips - all the time-
Same thing happens when I play game and watch a movie at the same time. I use Windows Media Player - full screen, and my game either in full screen or windowed. 1 of the 2 application is always windowed.
So please help me find what's happening. It wasn't happening before but it is happening for the past month or two.
I'm a little mad because the pc cost a lot of money and I tought it could handle 2 screen easily.
Thanks!
P.S. Anyone can explain to me why there's no HDMI port in the 480GTX??
  Quote Alex Quote  Post ReplyReply bullet Posted: 08 Sep 2011 at 12:24pm
It's most likely a driver or software issue causing this. Try using the Windows System Restore utility to revert back to a time when you were not having problems. If that does not fix it, I would try to uninstall and reinstall the latest graphic drivers from NVIDIA. If that also does not resolve it, a fresh install of Windows might be the best solution.
  Quote Utopi Quote  Post ReplyReply bullet Posted: 08 Sep 2011 at 12:35pm
Tyvm!
varindia View Drop Down
  Quote varindia Quote  Post ReplyReply bullet Posted: 15 Oct 2011 at 6:23am
Your hardware en-tensions are not matching(main HD and PS) as you primary configuration is bit older. You can refer some manual of the same. Use appropriate driver software
This page was generated in 8.789063E-02 seconds.
