$1600-$1700 SystemPost Date: 2007-10-06 |
Clinton
Groupie Joined: 08 Sep 2007 Online Status: Offline Posts: 298 |
Topic: $1600-$1700 System Posted: 06 Oct 2007 at 2:47pm |
I've posted this before I think, but my budget has gone down a little bit.. What would be the BEST custom build I can get with this budget? I'd like it to be able to play good games and to run smoothly. Also, I'd like it to be pretty fast and be able to run multiple programs smoothly. Anyone have any suggestions around this price range? I really need to go as cheap as possible while getting the best parts within this price.
skyR
Quote Reply Posted: 06 Oct 2007 at 3:06pm |
http://www.digitalstormonline.com/comploadsaved.asp?id=85601
E6750 is intel's best price performance processor. The baby can also be overclocked to 3.0GHz+ to match the higher end processor speeds. You can upgrade to a Q6600 if you going to run any heavy programs such as editing software, multiple game clients, encoding software, etc. 8800 GTS 320MB run any games great up to 1600x1200 resolution. If you plan on playing games at higher than 1600x1200 resolution, you could bump up to the GTX. You don't need a sound card unless you have a high-end sound system. HDD.. you do not need a big harddrive since you are on a budget. So I would assume you do not download a lot. Most average users can get by with 160GB no problem. There is also cds, dvds, ipods, external drives, etc for extra storage if you ever run out of HDD space. any questions or concerns? Edited by skyR - 06 Oct 2007 at 3:09pm |
commast
Guest |
Quote Reply Posted: 06 Oct 2007 at 3:46pm |
Here's what i have for you at $1690.
http://www.digitalstormonline.com/comploadsaved.asp?id=85604 I choose the Quadcore since you want to multitask and there are more apps now that can utilize the extra cores and the dual core won't be able to. With the Stage 3 options, DS can OC your system to around 2.8 and that should be enough to run anything. A 250 GB HDD is a must since HDD price is so cheap. I remember just a few years ago people were talking that we won't be able to fill up a 10-20GB HDD !! Looks what happen now. A single game install can take hundreds and hundreds of MB and that's now counting all your other apps (Vista alone takes up around 4 to 8 GB)!! Vista as your OS since you won't have any trouble with it on a new system. The 8800GTS card is a great card for your budget. The 667MHz is not the fastest RAM but it can be OC. Built-in audio is not that great ( Reatek audio chip) but that should be fine. |
Clinton
Quote Reply Posted: 06 Oct 2007 at 6:21pm |
Ok, and should I go with Vista? Can you take a look at that config commcast built for me and give me some feedback?
skyR
Quote Reply Posted: 06 Oct 2007 at 6:27pm |
His config has the ability to add another card for SLI in the future.
Two optical drives... if you have a use for them than go for it. Bigger HDD.. do you collect music, movies, tv shows? If not.. a bigger HDD is just a waste of money. Vista is personal preference. |
Clinton
Quote Reply Posted: 06 Oct 2007 at 6:36pm |
With that graphics card and everything, I would be able to play most games very smoothly and fast? Like Bioshock, COD, Battlefield? And would Vista have any effect on this? I hear that if your system comes built with Vists it works alright.
skyR
Quote Reply Posted: 06 Oct 2007 at 6:42pm |
Yep it will run them smoothly without problems.
Clinton
Quote Reply Posted: 06 Oct 2007 at 6:59pm |
Thank you very much!
AsTheStormClears
Newbie Joined: 02 Oct 2007 Online Status: Offline Posts: 11 |
Quote Reply Posted: 06 Oct 2007 at 8:29pm |
This was what I ordered and was 1620.00 when I added a surge protector.
System Configuration:
Case: Digital Storm Twister LITE (Black Aluminum Edition) Power Supply: 500W Thermaltake (Silent PurePower Edition) Processor: Intel Core 2 Duo E6850 3.00GHz (1333MHz Front Side Bus) (4MB Cache) Motherboard: nVidia 650i Core 2 Quad (By: eVGA) (nForce 650i Ultra) Memory: 2GB DDR2 Corsair at 800MHz XMS2 (Dual Channel) (Extreme-Performance) Floppy / Media: - No Thanks Hard Drive 1: 250GB (Western Digital / Seagate) (16MB Cache) (7200 RPM) (SATA) Hard Drive 2: - No Thanks Raid Option: - No Thanks Optical Drive 1: DVD-ROM/CD-ROM (DVD Reader 16x / CD Reader 40x) Optical Drive 2: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x) Network Card: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Modem: - No Thanks Video Card: nVidia GeForce 8800GTS 640MB (By: eVGA / Asus) (PCI-Express) TV Tuner: - No Thanks Sound Card: Motherboard Multi-Channel High Definition Audio (7.1 Channel) Physics Card: - No Thanks Cooling: Air Cooled Stage 1 (Certified Digital Storm Heat-sink) Case Lighting: Blizzard Internal Lighting (Blue Edition) (Cold Cathode Tubes) Round Cables: - No Thanks User Manual: Personalized Platinum Digital Storm Binder (Includes Paperwork/Benchmarks/CDs/Manuals) Windows OS: Microsoft Windows XP Home (Includes Service Pack 2) Restore Kit: Digital Storm Specialized Recovery System (DVD Image Based) Protection: - No Thanks Office: - No Thanks LCD Display: - No Thanks Surge Shield: - No Thanks Speakers: Logitech 2 Piece (Black Edition) Amplified Speaker Set Keyboard: Microsoft Multimedia Desktop 2.0 (Multimedia Keyboard + Optical Wheel Mouse) Mouse: - No Thanks my keyboard comes with a mouse Warranty: 3 Year Platinum Care Extended Parts & Labor Warranty Support: Lifetime Toll-Free Platinum Care Technical Support |
Quote Reply Posted: 08 Oct 2007 at 9:23pm |
Great config!
