1000w psu
Post Date: 2011-05-23
iizbored View Drop Down
  Quote iizbored Quote  Post ReplyReply bullet Topic: 1000w psu
    Posted: 23 May 2011 at 10:02pm
is it worth getting a 1000w psu for a single gpu and never going sli? Should i get 750w?
  Quote Alex Quote  Post ReplyReply bullet Posted: 23 May 2011 at 10:32pm
You don't need a 1000W then. A 750W will suffice.
  Quote iizbored Quote  Post ReplyReply bullet Posted: 23 May 2011 at 10:34pm
Even for future gpu?
maxyme View Drop Down
  Quote maxyme Quote  Post ReplyReply bullet Posted: 23 May 2011 at 10:38pm
in the future they will probably use the same or less power. because they are optimizing them.
Steam:pcmaster160
  Quote iizbored Quote  Post ReplyReply bullet Posted: 23 May 2011 at 10:39pm
Thats awesome thanks allot
  Quote maxyme Quote  Post ReplyReply bullet Posted: 23 May 2011 at 10:46pm
yep. just look at the 5xx over the 4xx. they improved power usage slightly as well as increasing performance. Also amd is way better with power saving than nvidia with their recent cards only needing 650w psus.
Steam:pcmaster160
  Quote iizbored Quote  Post ReplyReply bullet Posted: 23 May 2011 at 10:47pm
I believe nvidia has stronger cards then amd so im staying with nvidia even though you cant really prove it.
  Quote maxyme Quote  Post ReplyReply bullet Posted: 23 May 2011 at 10:49pm
they are hard to compare differant archetecutres ect. and honestly if i had the extra money to pay $100 markup on a gpu i would because amd drivers suck. I've had my pc for a month and had 2 issues with it. one that took 2 days to figure out....
Steam:pcmaster160
  Quote iizbored Quote  Post ReplyReply bullet Posted: 23 May 2011 at 11:05pm
Exactly even though amd is better in some ways but nvidia has good support and strong cards
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 24 May 2011 at 4:23am
for sli 570 and a good oc, you need a corsair 1000w psu, a 750w will be pushing it, if your card is a lower card then a 750w can do sli.
For a single gpu, and future upgrades a 750w corsair is what you want.
