100 degrees F
Post Date: 2011-02-15
funeralpyre88 View Drop Down
  Quote funeralpyre88 Quote  Post ReplyReply bullet Topic: 100 degrees F
    Posted: 15 Feb 2011 at 5:03pm
Is it a bad idea to run a computer in a room that is 100 degrees fahrenheit?
Does the weather affect the computer?
The reason I'm asking is because I might be too lazy to put air conditioning in my room this summer.
Is there a "safe room temperature" for operating a computer?
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 15 Feb 2011 at 5:52pm
May want to downclock your processor/gpu a bit if they're overclocked.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
corybo7 View Drop Down
  Quote corybo7 Quote  Post ReplyReply bullet Posted: 15 Feb 2011 at 5:53pm
yes....that would be a bad thing to run a PC in a room that is 100 degrees Fahrenheit. All that hot air would be getting blown on already hot parts inside your PC causing the temps to rise even further which can cause system instability....and cause damage.....
usually you want a room with an ambient temp of around 75F or lower...that is ideal..
"Kindness is the Oil that keeps Friction out of Life" -myself
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 15 Feb 2011 at 5:54pm
100c is equivalent to 37 or so C. Not too painfully bad, just not too nice for a well overclocked processor.
Edited by ablahblah - 15 Feb 2011 at 5:55pm
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote Alex Quote  Post ReplyReply bullet Posted: 15 Feb 2011 at 7:43pm
It's not ideal, but, the unit will still work. If it's put under heavy stress, it may be unstable. I don't recommend it.
Tidgxor View Drop Down
The Kokopelli kid
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 15 Feb 2011 at 9:16pm
As has been mentioned, its doable, just not recommended. I think this is primarily geared towards gaming rigs, or just any rig in general that will be heavily stressed. If you are talking about a computer, with stock settings, doing non-intensive stuff, then 100F won't be much of an issue, I speak from experience.
justin.kerr View Drop Down
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 16 Feb 2011 at 8:55am
It will all depend on the cooling solution, going from a 75F room to a 100F room will raise temps appx 15C, that alone will more than cut the life of all the silicon in 1/2. But a slightly beefed up cooling system, and mild overclocks, would still keep temps lowe than a all stock setup.
This page was generated in 3.808594E-02 seconds.
